Memory Slot not working
Whan I insert memory card it is not detected
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Are the pins inside the slot still straight? You can check with a bright torch whether one of them might be bent or broken. Does one of them look different, corroded, not so shiny anymore? If the pins are okay, you can try to clean the slot with gentle blowing. Did you format the memory card with an external device? Did you try with another memory card? Sometimes they simply die.
由完成的 分享
添加一条评论
