跳转到主内容
加入维修社区 - 创建账户
Ideapad 5-15ITL05 笔记本电脑 - 型号 82FG。该机型于 2021 年 10 月发布,配有触摸屏,可当作平板电脑使用。
Setup notice- Default boot device missing or boot failed
During starting up it shows the default boot device missing or boot failed, insert recovery media and hit any key. Then select 'boot manager' to choose a new boot device or to boot recovery media.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
that usually means that there is an issue with your hard drive or there's something wrong in windows. when pressing any key does anything show up in the boot manager?
这个答案有帮助吗?
得分 0
3条评论:
It just shows instructions, like up and down to change options. however there is nothing else in the Menu
完成的
sounds alot like the ssd has failed or has come unplugged inside of the laptop. try unscrewing and taking off the back cover of the laptop and checking the connections to the drive, and if you have another computer you should attempt plugging the drive into it to see if it shows up in the windows file explorer
完成的
Yo tengo una que pasa casi lo mismo y se queda en el Logo, No es SSD, no es Sistema operativo. Quise formatear y no pude. Se queda en el logo, me deja a entrar en modo arranque y todo pero ya no pasa del logo
完成的
添加一条评论
添加你的答案
Atul Rana 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 32
总计 746
