跳转到主内容
The iFixit Precision Bit Driver is an aluminum or plastic handle that fits 4 mm bits.
9 个问题 查看全部
What is the best way to remove rust off a a screwdriver bit
Ive started noticing that one of my commonly used screwdrivers got rusted up a little, The rest seems to be fine (ones that i dont use alot). Another thing I found is that the place where you insert the bits also got rusted a little. Here are the images of the rustiness. How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
00 Wire wool and a squirt of WD40 will remove the rust. Then i would lightly coat in 3 in 1 oil to protect it.
这个答案有帮助吗?
得分 0
添加一条评论
@sploo soak it in some Citric Acid (available in pretty much any store like Walmart etc. You can find it in the food isle or the cleaning isle. Dishwasher and washing machine cleaners are commonly citric acid). Soak the tool for a bit and then you can wipe the rust off. 3-in-1 oil is good to apply after or use some gun oil.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Artem Ivat 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 41
总计 169
