跳转到主内容
The earliest mention of these Hard Drives were 2004, 3 years after the release of the first iPod. Welcome everyone, to the 1.8" Toshiba Hard Drive page, no matter if you've stumbled across here from the iPod page, or found one of these Drives in your drawer or from the exposed elements, if you wanna fix it then you've come to the right place!
2 个问题 查看全部
My hard drive is corrupted
When I connected a hard drive in my laptop my laptop performance is very slow. What can I do to fix it and recover my data?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
最有帮助的答案
What is your system and OS?
From your description the drive likely needs to be defragmented as over time the files get broken up across the drive platters making the drive work harder. There are tools which can fix this but before doing anything I strongly recommend backing up your stuff.
这个答案有帮助吗?
得分 1
添加一条评论
@gadgetsale let us know the exact make and model for your Hard Drive. I would suggest an external Hard Drive Enclosure to install this hard drive in. Then use a different computer to recover the files from your drive.
这个答案有帮助吗?
得分 1
添加一条评论
Defragment it, make sure you have the correct drivers, clean off connectors with compressed air. If nothing else works, wait three days and it will magically work. Happened randomly with one of my HDDs.
这个答案有帮助吗?
得分 1
添加一条评论
Data recovery is NEVER a DIY topic, send it to a professional recovery service.
这个答案有帮助吗?
得分 0
5条评论:
You’re wrong, that will allow people to peek in the data and their personal privacy.
完成的
Please, do NOT suggest that… professional cost money and risk. They can peek in the data and privacy of the customer depending on the services.
完成的
This is incorrect.
完成的
@cedricilamar If going to a pro has risks, doing it DIY has MORE risks, not to mention it usually costs more money if you want to invest in the tools just for one recovery.
完成的
@cedricilamar Well nobody can peek into your privacy when the data is destroyed. Do you want the data or not?
完成的
添加一条评论
添加你的答案
Gadget sale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 815
