跳转到主内容
加入维修社区 - 创建账户
Vertical line. All other working fine
LG 55LA6200 -TA 3D tv showing verical lines. All other working is fine. Pls guide for repair
Update (11/03/23)
Hi,
Many thanks for the reply.
I have already tried [ressing cables in image 3 but there is no change. I hope I have pressed right cable.
Also I see the lights are symmetrical. Does it indicate fault somewhere else?
Regards
Girish
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@girishdayal that is a problem with the TAB connections on the ribbon cables from the driver boards to the LCD. If you remove the back of your TV and identify the ribbons from the driver boards (small , skinny boards that connect to the LCD. That are NOT removable) Apply some pressure on those cables at the place where the line originates from. If that changes the line you know that it is a TAB error. Sometimes applying that pressure is enough to fix it before replacing it. Take some pictures of what your TV looks like with the back off so that we can show your were the tabs should be. Use this guide for that.
TAB errors occur where the "bonding" that adheres the thin ribbon cables to the actual panel. Take a really close look at those and apply some gentle pressure on them (with your TV on). You will most likely see that the lines either change or disappear That is incredible difficult to fix but sometimes some downward pressure applied by some adhesive tape etc. can make them go away for a while at least. If you have trouble identifying the ribbon and TAB just post some more images of what you see on the top of your LCD panel. It should look something like the attached images.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Girish Dayal 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 343
