Why is my laptop is overheating?
for small time usage like 10 to 15 min only my laptop is over heating
Since your laptop is only about 3 years old I would just blow the dust out of the fan and anywhere else you see a build up of dust with some canned air. Don't touch anything. Static electricity can damage components. Be careful of all wires, ribbon cables, etc.
Click here to open back of laptop to see fan
这个答案有帮助吗?
its not been 1 year also since I bought
HI @ss321,
1 year only then do a backup of your HDD/SSD and take the laptop back to the dealer for a warranty repair or exchange.
When you say ovrheating, do you mean it is warm in your lap (not a huge problem) or is it shutting down from being too hot (big problem!)
Batteries get hot when they charge from a low charge state. Could be the sign of a failing battery if your battery life is very short.
CPU gets hot if the fan and heatsink system are not operating properly. Check to see that the fan turns smoothly. As another has suggested, blow out any dust from the fan area but hold the fan blades, over spinning the fan could be bad. Also, perhaps the thermal paste between the CPU and cooling system is inadequate. You may want to dissassemble and re-paste the junction.
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 59
总计 235
