跳转到主内容
加入维修社区 - 创建账户
Logitech G502 Lightspeed 是一款无线游戏鼠标,与同系列的 G502 Hero 有线鼠标共享大部分规格。型号为 MR0076,于 2019 年 5 月发布。
Scroll wheel doesn't respond.
I used 70% isopropyl alcohol to remove fur on the inside of the wheel, but after waiting for the alcohol to dry, the scroll wheel started to respond less and less over time until now, where it does nothing.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Why use alcohol at all ??? In the future why not just use your fingers and small tweezers to pull out the hairs?
Another very important point is that 70% isopropyl alcohol is for disinfecting NOT electronics, as it has to much water in it often with minerals which leave deposits which can short electronic circuits. 99% or very close to that is preferred and is available at electronic component supply shops.
You may also have to wash the area with pure distilled water available as pharmacies. Make sure it is completely dry before using mouse again as water will short the electrical circuits.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cadfg 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 60
总计 1,138
