跳转到主内容
加入维修社区 - 创建账户
Not able to boot from ssd .
I have added an ssd to the laptop have windows 10 and the harddisk is containing the previous os.
But when turned on the default boot option is harddrive rather than ssd.
When tried to change it unable to change .
Every time i need to press f9 and select the drive to boot from.
Hp 15s-du3053tu
Update (10/27/23)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
[image|3113785][image|3113786]
This is images of the screens during the operation
由完成的
@jayeff
I think one of the drive is not showing as bootable device.
What can be done for that.
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @basil33672
Try the following and check it it resolves the problem.
Press Win key + r key (both together) and type msconfig in the box.
In the Boot tab:
Select the OS (drive) that you use on the next boot and select Set as Default.
Set the Time Out to 0 seconds
Click Apply and restart the PC.
If you want to use the other drive then follow the same procedure again and select the other drive as default
这个答案有帮助吗?
得分 1
6条评论:
Okay i have checked in that way but still it is going for automatic repair and stuck in the same situation
由完成的
@basil33672
Getting a bit confused.
You said that Win 10 was on the SSD and the "previous OS" was on the HDD yet in the image you posted shows the Win10 OS is on the "C:" drive.
Was the "previous OS" Win 10 also i.e. do you wish to have 2 x Win 10 systems?
How did you install Win 10 on the 2nd drive?
由完成的
Hey,
Actually the issue is we are unable to select from the boot option os manager where they have mentioned press F5 F6 to move up and down then hitting enter key does not work to make the primary boot device as ssd.
You can seen from the image.
Do you suggest any other keys to make the selection.
Which may the solve the problem.
Since during booting its trying to boot from the hard disk where the windows os in the hard disk has been crashed. Thereby always it going for automatic repair.
由完成的
@basil33672
What OS is on the hard disc that crashes?
Was the SSD Win 10 install an new install or was it an existing drive from another PC?
由完成的
Hey,@jayeff
i am able to set ssd as primary boot .
But another issue observed.
When the system undergoes sleep and when wakes , it goes for automatic repair where the primary boot option is changing back to hard disk.🤯
I don't understand what is happening.
Please help me if you have any idea.
Windows 10 home on hard disk.
由完成的
显示更多的1条评论
添加一条评论
添加你的答案
Basil 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 488
