跳转到主内容
加入维修社区 - 创建账户
适用于支持多点触控的 Apple 无线鼠标的维修指南和故障排除信息。型号 A1657 或 A3204。
Magic Mouse 2 in not connected
When I switch on the Magic Mouse 2... on screen says "Mouse Connected". Few seconds later, on the screen says:" Connection Lost" I'm thinking about the battery of the mouse( 2 years now, non stop working). But the battery is a common on. Thank you in advance for your help. Panagiotis Badalakis
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
While its possible the battery has failed, I would first give the mouse a good over night charge (better than 8 hours) use your iPhone charger as your system likely won't let your mouse charge when in sleep mode.
In any case heres the guide and the battery info 妙控鼠标2电池更换
这个答案有帮助吗?
得分 1
2条评论:
thank you very much, dear dan. i saw that the battery costs about 85$, and the new one round 100$. does it worth it?
由完成的
@panagiotis81413 - For some people that $20 does. For me it’s the principal of throwing away a still functional device when it only needed a battery. We’ve become too throw away wasting resources.
But, before you make that jump make sure the battery is truly bad. Often times it’s just not getting a good charge.
由完成的
添加一条评论
添加你的答案
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 31
总计 476
