跳转到主内容
Repair and disassembly guides for Brother printers.
352 个问题 查看全部
MFC-L2710DW no power
Worked fine no issues 2 days ago and now it’s dead. I’ve tried all the troubleshooting steps I could find (unplug, hold down power button while plugging it back in) online and nothing is working. Brother support told me to take it to a service center, any other suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@lauren71714 i am wondering if this "and now it’s dead" mean there is no sign of life. If so I would start with the power supply
Make sure that it:
(1) The AC input power supply described on the rating plate of the machine should be within ±10% of the rated voltage.
(2) The AC input power supply is within the regulated value.
(3) The cables and harnesses are connected correctly.
(4) The fuses are not blown
To determine if this is a power board issue, we would need to see what it looks like in your printer That way we can see what you see. 在已经存在的问题里加入图片 The power supply is a low voltage power supply assembly and can be replaced separately.
Printers are a different beast altogether and never straight forward :-) You can download the service manual for your printer from the bottom of this page Brother Printer Let us know what you find out.
While you work on your printer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lauren 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 34
总计 168
