跳转到主内容
加入维修社区 - 创建账户
一款小巧且极简的时钟,由瑞典公司 IKEA 制造。该公司以其家具、迷宫般的家具卖场以及美食广场而闻名。
Open the front cover
How do I dismantle the clock. It has no screws on the outside
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
A photo of the back would be good with the battery removed. Presumably there is a hole in the back for a battery? There maybe a hidden screw in the battery compartment.
Else the casing is clipped together with hidden clips probably in the middle of the sides? In which case use a spudger pry tool to ease the back off, maybe starting in the middle of the side with the widest gap. A blunt butter knife might work but might scratch the plastic more. Some clips might break.
If it glued even more might break. Possibly slightly warm it first.
Do you want to take the cover off to remove condensation following use in a bathroom. Maybe just put in a warm dry room for a few days. Or drill a few holes in the back?
这个答案有帮助吗?
得分 1
添加一条评论
How to open digital clock ? When no screws are visible outside. I have screen problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eskay 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 62
总计 757
