跳转到主内容
加入维修社区 - 创建账户
针对 MacBook Pro 13"(配备第二代 Apple Silicon (M2 芯片) 和 13.3 英寸视网膜显示屏)的维修指南和说明。型号 A2338。于 2022 年 7 月 15 日在 WWDC 2022 大会上与 MacBook Air M2 同时发布。
Screen Problem, blurred lines at bottom of screen.
Hello,
My Mac have developed some blurring at the bottom on the screen. It covers the entire width of the screen and is about 1/4" high.
I took it into Apple and they said it needed "screen controller" repair costing about $600.
Has anyone else had this issue and was able to perform a fix themselves.
Thanks
Andrew.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Sadly its out of warranty !!!!!!
由完成的
添加一条评论
2个答案
Ouch! Your system should still be under warranty!
Double check if it is, then go to anther Apple store or dealer as this should be a free repair!
Unless there is visible damage around the displays chin area I can’t see any reason to be denied.
这个答案有帮助吗?
得分 0
2条评论:
由完成的
@andrewusherwood - If its just outside the window by a few weeks I would still press Apple, But you need to lean on them a bit. Be pleasant but firm, escalate it up the food chain, I'm sure you should be able to get this fixed for free!
由完成的
添加一条评论
I have the same problem, just just happen just I made an upgrade to Sonoma, I a few weeks after. Now, I don't know if its is hardware problem, or is it an software/driver issue. How can I tell, and take appropriate. I reverted to the original OS that come with the laptop, but the issue still persist.
Hope some can help..
Thanks
这个答案有帮助吗?
得分 0
1条评论:
@georgetuges - Plug in an external display, if the image is clean on it, it tells us your internal displays logic is damaged and you likely need a new display assembly.
由完成的
添加一条评论
添加你的答案
Andrew Usherwood 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 26
总计 1,012
