跳转到主内容
加入维修社区 - 创建账户
Optoma HD20 是一款于 2009 年 8 月发布的 1080p 分辨率家庭影院投影仪。维修此设备需要使用螺丝刀和撬具。
remote no powering on unit
my hd20 remote will not power on my unit
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi @charlespeti4062
Troubleshooting steps:
Have you checked/changed the batteries in the remote?
Use a digital camera or the camera app in a mobile phone to test if the remote is working OK.
Turn on the camera or open the camera app in the phone and then point the end of the remote, that is normally pointed at the projector, towards the camera lens so that it is visible in the LCD screen.
Press the Power button on the remote and you should see a light turn on at the end of the remote, when looking at the LCD screen.
If you don't, then try any other button and check.
If the light doesn't turn on when you press any button, try the test on another known working remote e.g. TV remote, to make sure that you're performing the test correctly.
If you still don't see the light when pressing any button on the remote, check that there's no button stuck down in the half operated position. If they appear to be all OK then the remote is faulty and would need to be opened and checked.
If you see a light on the remote when the Power button is pressed, then there's a problem in the projector.
Check that there's nothing blocking the projector's IR window from receiving the signal from the remote.
Here's the ifixit Optoma HD20 guide that may help, at least to gain access so that you can check if there's anything obviously wrong e.g. burnt out components etc.
这个答案有帮助吗?
得分 2
1条评论:
these were 2 brand new units right out of the box. i returned them both had the same problem, new battery's. they worked a couple of times them , wham out of business
由完成的
添加一条评论
添加你的答案
Charles Petit 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 48
总计 1,313
