跳转到主内容
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
The keyboard backlight is not working
Hello everyone!
I bought a used MacBook Pro 16 (2019), and it needed cleaning. I removed kilograms of dust, put everything back in place (everything is now in perfect order), and just today, while watching a movie in a dark room, lying in bed, I discovered that the backlight isn't working. I usually use the laptop connected to an external display, so I didn't notice it immediately. Plus, I don't remember when I bought it whether I checked if the backlight was working.
Please help me figure this out. Does the keyboard backlight have its separate cable? How is it connected to the motherboard? If anyone has photos of this board and an example of how the power and control for the backlight are organized, I'd appreciate getting those photos. Could I have simply forgotten to reconnect a cable during the MacBook's reassembly?
Thank you, everyone!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
PS. Yes, I reset the PRAM and SMC. That didn't help.
完成的
添加一条评论
3个答案
已选择的解决方案
It sound like you may have forgotten to reconnect the keyboard backlight cable or the connector is not clasped. Review Step 50 in this guide 2019年16寸MacBook Pro 电池更换
If it’s seated correctly then inspect the ZIF connector is latched, that’s the little tab you folded up to release the cable and now you need to fold it down.
这个答案有帮助吗?
得分 1
1条评论:
@danj
You were right. The ZIF connector simply wasn't fastened.
Thank you!
完成的
添加一条评论
Did you use any conductive liquid to clean the keyboard? If that is a yes, it may have damaged the backlight.
这个答案有帮助吗?
得分 0
1条评论:
@tanveerzubair
No, i didn't
完成的
添加一条评论
how do i solve mine please. the keyboard backlight isn't working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Eugene K. 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 76
总计 1,106
