跳转到主内容
加入维修社区 - 创建账户
于2019年11月发售的MacBook Pro 16''的维修指南和拆解信息。型号A2141,EMC 3347。
Camera and keyboard backlight not working
Hi! I was cleaning my Macbook and changing thermalpaste. After all I plugged every cable and put all screws in. Unfortunately now camera and keyboard backlight are not working. I think keyboard backlight is related to camera, because auto brightness is not working too. What could possibly go wrong? I think nothing has broke.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
12个答案
最有帮助的答案
Hi
Have you checked all the connections are seated correctly?
this seems quite strange if you haven't damaged anything, try reseating the screen connectors and keyboard connectors
if that doesn't work inspect the connectors on the board and parts for damage(burned pins, torn cable ,caught under screws ...)
if you can't find any damage try cleaning the connectors both part and board with isopropyl alcohol and tips/cotton buds
if the above dent work let me know any we can have a more in-depth look at things
Hopefully this helps
这个答案有帮助吗?
得分 2
5条评论:
Hi @hellomacos I redone everything and nothing has changed :/ Do you know which connector is for the camera and light sensor?
完成的
Hi
On the model I believe the camera and light connector part of the screen connector
lets have a closer look
restart your Mac and hold the D key on the keyboard
here's a link on how to do it too:-)
https://support.apple.com/en-gb/HT202731
完成的
No issues found :/ That's really weird.
完成的
System information shows that FaceTime HD Camera is available...
完成的
@Kacper Barcik
That’s soo strange!
Let’s try and boot into safe mode
Here’s a link on how to do it
https://support.apple.com/en-gb/guide/ma...
Safe mode will disable the non necessary features and can helps with diagnostics:-)
完成的
添加一条评论
Have the same problem. Screen replaced. a1990. Chip T2.
Keyboard backlight works until I log in.
I tried to Pram, SMC, macos reinstall. I see that reviving and restoring bridgeos will not help also.
Is there any solution how to disable ambient light sensor & camera by terminal?
这个答案有帮助吗?
得分 1
1条评论:
I even try to disconnect the internal screen and used a secondary monitor.
Anyway, it shows Serial number: ? and backlit doesn't work
完成的
添加一条评论
On my 2019 MacBook Pro 16" I replaced the display cable to bring my camera and keyboard backlight back. Patience needed, logic board has to come out for this repair. I have read in a number of posts that the T2 chip is the issue when replacing the screen and have encountered that on other Macs but found one fellow who recommended changing this cable out and it worked for me! Here is the iFixit part, MacBook Pro 16" (2019) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.图片
产品
$14.99
这个答案有帮助吗?
得分 1
2条评论:
Just installed a new one and it helps, thank you very much man!!!
完成的
Just to mention that replacing this cable was also the fix for me. I lost my camera and keyboard backlight after disassembly and had all but given up but then I bought this part off eBay and to my surprise it fixed the issue.
完成的
添加一条评论
Out of curiosity is your Mac a T2 chip Mac?
I'm noticing that the t2 chip controls the FaceTime camera and ambient light sensor, that being said I wonder if using another Mac, and reviving the T2 BridgeOS firmware would reconnect the hardware to the system? Has anyone tried this?
I'm having the same issue after replacing the screen on a 2019 MacBook Pro. Keyboard backlight works until I log in .... once logged in the keyboard backlight stops working and brightness can't be turned up, as well the FaceTime camera does not work either. I want to try flashing the T2 Firmware but I don't have access to another Mac to do it.
See in the system report below the camera shows under USB BUS T2 Chip. The camera and the ambient light sensor are on the same circuit board in the screen so I'm assuming it's all connected. BUT how do we make the T2 chip BridgeOS recognize it?
这个答案有帮助吗?
得分 0
添加一条评论
Hey! Did you manage to solve the problem? I have the exact same problem and my camera is not recognized in system info. I got a motherboard repair after a capacitor failure by a third party technician who also repasted and cleaned the Mac, so it seems weird that he damaged something while repairing.
这个答案有帮助吗?
得分 0
添加一条评论
No. It appears that maybe the ALS (ambient light sensor) & camera since paired to the T2 chip will have to be reassigned to the T2 chip. Even reviving and restoring bridgeos to the T2 chip with Apple Configurator didn’t work. Apparently Apple themselves has to pair them again but they won’t touch it since the repair was not done by them.
Oh well, no backlit keyboard or camera for now I guess!
这个答案有帮助吗?
得分 0
1条评论:
Are you sure about that? I searched online and it seems that they're not paired like they are in iPhones, so apparently no need to pair them from apple.
完成的
添加一条评论
I have a macbook pro 2019 A1989 with a t2 chip replacement, but neither the camera nor the keyboard lights up, does anyone have a solution?
这个答案有帮助吗?
得分 0
1条评论:
did you ever solve this, I also have the same issue.
完成的
添加一条评论
Just experienced the same thing. I replaced the screen of A2141 2019 and now my camera and backlight isn't working. Any solutions?
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
Same issue on a A2141 2019, post an ifixit battery change.
I double checked everything (torn cables, assembly) everything looks ok, however the camera and keyboard backlit are not working.
I still hope, it's something I did wrong, not Apple locking the t2 chip.
这个答案有帮助吗?
得分 0
添加一条评论
I'm having the same issue. i changed my MacBook Pro A1989 display, and my camera and keyboard backlight stopped working. I even replaced the display twice, switched back to the old display the same issue.
I have done virtually every fix, SMC reset, and cleaned the clip's surface, but nothing has worked so far.
这个答案有帮助吗?
得分 0
1条评论:
Not sure if a new display needs to be paired to the T2 chip but the original should definitely work.
Try swapping out the short display cable (MacBook Pro 16" (2019) Display Cable) as this was the fix that worked for me when things went wrong after disassembly.
完成的
添加一条评论
Check the connection of the camera/ambient light sensor cable (usually routed through the display hinge)—it likely got loose or misaligned during reassembly.
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem on a 2019 MacBook Pro 16 inch no camera and no keyboard backlight. Also in the keyboard settings, there was no setting for the keyboard backlight to turn off and on.
I change the flex cable for the display and that fixed it.
@petermacdoctor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kacper Barcik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 61
总计 4,105
