跳转到主内容
加入维修社区 - 创建账户
Powerbeats Pro 真无线耳机的维修和拆解信息。于 2019 年 5 月发布。型号:MV6Y2LL/A、MV702LL/A、A2047。
How do I replace worn out batteries
The powerbeats pro charge to 100% in the case and shut off after 30 minutes of use
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
I ordered a pair of Varta CP1254 A3 batteries advertised for Powerbeats on eBay but the 5.4mm height is about 1mm taller than the OEM battery. It doesn't fit. All the listing specs also have 5.4mm height? Any suggestions?
由完成的
@bloodygalah
Have you checked the original battery to see what model number is stamped on it?
由完成的
@jayeff
No markings on the OEM battery at all I'm afraid
由完成的
@bloodygalah
That makes it tough.
You may have to measure the dimensions and then see if you can find a similar size "3.7V 0.2W rechargeable battery with solder tabs".
Soldering wires to a battery is dangerous as it heats the battery too much. That's why getting batteries that already have them factory fitted is better and safer
由完成的
@bloodygalah
Apologies, must have had a brain fade.
Obviously not AA size.
Also since the original has no markings make sure that if you do find a replacement that you connect it correctly i.e. +ve side of battery to +ve wire from the board if wires are coloured then red wire is +ve and black wire is -ve.
You may need to have a DMM (digital multimeter) to find out which is the +ve side on the original battery if the connecting wires aren't coloured differently.
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi @harveyhimel
Here's the ifixit Powerbeats Pro 拆解 video that shows how to access the battery.
The battery make and model number is Varta CP1254 A3. Search online for Varta CP1254 A3 to find suppliers that suit you best.
Here's an image from the video that may help
(click to enlarge)
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Harvey Himel 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 53
过去 30 天: 185
总计 15,256
