跳转到主内容
加入维修社区 - 创建账户
volume/power dial broken
Hello, the volume/power head has snapped in two after a fall from standing on an uneven rug to flat on the floor.
The dial is in two parts almost evenly. One half still attached, the other loose.
Motor functionality via Ortho remote fails as does physical manipulation of the dial. the dial believes it is at 100% and returns to 100% after physical rotation of the (remaining) dial and when using the ortho remote.
The Unit suffered no external damage aside from the dial.
However, when attempting the Loop functionality from playback on FM and BT, the unit automatically enters Playback Speed Mode.
I can hear the volume motor working away when i have the device on line in with no input active.
Kind thanks,
Aaron
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
@aaronbenn Can you upload a picture of the problem? 在已经存在的问题里加入图片
由完成的
I’m experiencing the exact same issue — the radio fell and the knob came off. I tried to repair it using super glue, which holds the knob in place mechanically. It snaps into the ‘off’ position, but the dial itself no longer functions. As a result, the radio won’t turn off and the volume stays stuck at 100%.
由完成的
@retoschneller Exactly the same thing happened to me, can this volume knob be repaired?
由完成的
添加一条评论
2个答案
had the item repaired at cost by manufacturer, i think was around £80 inc transport. turnaround was very quick and since ive had no problems and been extra careful.
have contacted support and requested a feature add, a stand to slot the OB-4 into to keep it upright and topple free,
这个答案有帮助吗?
得分 0
1条评论:
I contacted Teenage Engineering directly via their websites 'contact us' page
由完成的
添加一条评论
How did you reach them? There isn’t any direct customer service info listed, just a redirect to ifixit.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Aaron Benn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 53
总计 865
