跳转到主内容
Screen is showing vertical lines and image is duplicating on screen
In my phone screen is showing vertical lines and every image is duplicating on full screen ,how can I solve this issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
@vibhor30564 we really would need to see what this all looks like. Post some good pictures of that with your Question.
It is possible that this is a bad display. It can also be a bad connector (check for corrosion, broken and bend pins) Finally, it is possible (unlikely) that this is an issue with the circuit board. Start with a new display.
Since iFixit does not yet have a guide for this, use the one from here Replacements are readily available at plenty of online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
You mean to say I should get the display changed ?
But phone was not felt from height not even fell in water so how can these lines occur ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vibhor 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 13
总计 225
