跳转到主内容
加入维修社区 - 创建账户
hp 15 f100dx keyboard connector
keyboard connector was damaged by kid disassambly
has anyone managed to replace this?
(or even find a connector)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@oldrepairer do you have the motherboard out. Can you post some good pictures of it with your Question. That way we can see what you see. 在已经存在的问题里加入图片
完成的
添加一条评论
2个答案
已选择的解决方案
@oldrepairer looks like the motherboard for this computer should be a Quanta da0u99mb6c0 That means that the keyboard connector is a (50698-03201-001) DFFC32FR038 connector. That was the easy part. A quick search did absolutely show nothing even close to that. Either it is an obsolete connector or nobody lists those numbers as to not run into issues with Quanta. Manufacturers are sometimes contractually bound to only sell to them and not the public etc. (Proprietary connectors) Now if you are as "frugal" as me, I would check places like ebay, aliexpress, alibaba etc for a donor board. The same motherboard just not working etc. Then use that to harvest the keyboard connector from it. Lots of kapton tape and a heat gun with a small nozzle (or a soldering iron with a large T-shaped tip) can get that accomplished.
这个答案有帮助吗?
得分 1
添加一条评论
Yeah, that was the last ditch idea.
Just can't find a 32 pos. connector anywhere.
Amazing that you actually found the part number.
Gave you credit for the accurate answer.
Wish me luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
OldRepairer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 236
