跳转到主内容
Repair and disassembly guides for electronic keyboards.
216 个问题 查看全部
Yamaha psr e343 battery port change
I opened my keyboard after a long time like years and I had the batteries inside it too, so now all the batteries are rushed and the whole battery port is ruined. I did try starting up the keyboard with charger and it lights up but only when I keep pressing the ON button, so I think everything is good it just needs a repair on the battery port.
I needed to know from where to buy this battery port too.
Thanks!!!!!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
I think you may struggle to buy just the battery port but if you manage to pry it out you could clean it with rust remover and a wire brush and restore it to a good condition. These parts are normally just some nickel coated plates and springs.
I would try to carefully pry them out of their socket (might need to take them out from the underside though) and then soak them in rust remover, then give them a good scrub with a wire brush. Sometimes you can use finer grit sandpaper to remove the corrosion.
这个答案有帮助吗?
得分 2
添加一条评论
@mohitjoshi31517 you can replace the spring terminals from battery assembly, but like @honakrisi already alluded to, it's a PITA however, it is possible. Page 17
from the SM PSR E343 Removing it might help you to clean it and possibly restore it. BTW I am a strong believer in Citric Acid as a rust remover. It's considered non-toxic and safer for the environment than most commercially available products
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mohit Joshi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 18
总计 60
