跳转到主内容
Why is my phone uses itself?
It scroll by itself. It open apps by itself
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@natinael that is what is called "Ghost Touching" it is most commonly caused by a separation with the digitizer assembly. Sine the LCD and the touchscreen on this model are fused, replacing the complete display assembly should fix this.
Of course you also want to check your software. MAke sure you have everything updated. If nothing else you can try and reset your software. Of course, make sure you have all of your files backed-up.
Since iFixit does not yet have a guide for this, use something like this video Replacement display assemblies are readily available at many online places. Purchase it from a vendor that you trust etc.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Natinael 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 12
总计 212
