跳转到主内容
The Samsung Galaxy A10e is a lower-mid range Android device released by Samsung in February 2019. Identifiable by model numbers SM-A102(U, U1, W, or DL).
24 个问题 查看全部
annnddd its a punctured battery!
Kinda a dumb question, but i dont want to set my house on fire lol
Basically, the screen is being pushed out of the phone, but the case is also bending, like as if someone had tried to get into the phone, rather than the battery swelling.
won this in a lot, so i have no clue what happened to it, but the screen is shattered on the upper half and the sim card slot on the case is collapsing which is making me think this could have been a failed attempt at replacing a screen..?
UPDATE
well i opened up the phone and found this:
and there is not guide how to safely remove this battery yet, so i have actually no clue how to safely remove this battery.
thanks for any help <3
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@timtomissus the removal of the battery works the same way. I know you know how to but just in case, here is a video to remind you. I prefer to remove those batteries in a well ventilated area (that stuff does stink something fierce, if it does open up) and have a small metal container of sand handy. Just in case the battery should "vent with flame" which has not yet happened to me (Lithium and Water don't mix ;-). Just use common sense and don't poke holes in it on purpose. It's not quite like ordnance disposal ;-)
As for the other damaged parts, just that could come from some failed repair attempt but we would need to see what that all looks like.
这个答案有帮助吗?
得分 1
8条评论:
the sim card holder is missing, the daughter board flex is damaged, and the screen is damaged, but it seems fine other than that :)
although i will note the battery was disconnected when i opened up the phone, which is a bit weird as they should have just removed the entire battery if the managed to get that far..
完成的
@timtomissus dang. Sounds like somebody that's all thumbs was working on it.
完成的
@oldturkey03 anddd another one it this lot also has a hidden punctured batt :/
完成的
@timtomissus that sounds like fun. Hopefully it was not to expensive. Enough of the same model for you to build one good one?
完成的
@oldturkey03 yeah, all I need is a new screen and a batt and I should have a good one :)
and I cant get the logic board out of the frame though :(
完成的
显示更多的3条评论
添加一条评论
添加你的答案
timtom77 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 83
