跳转到主内容
Repair guides and support for the sub-brand of Kodak consumer digital cameras, not including the printer or printer dock portion of the EasyShare line.
169 个问题 查看全部
How do I replace a broken LCD on a Kodak Easyshare C643?
How do I Get the information on how to replace a brokenLCD on Kodak EasyShare C643?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Liston Bailey, just looking at the service manual and it appears that its not a terrible job. Point to remember for sure is that to prevent injury, you must do a discharge of the CAPACITOR. Remove the screws on the outside of the camera body. They show as number 1 on the parts diagram. There are two on the right, two on the left and two on the bottom. At this time you should remove the front case. There are two more screws, bottom left and top right, once you remove those, the back case should come off. You now should have access to the LCD screen. Open the clip, tab, that hold the ribbon cable to the connector. The LCD should now swing out. battery door and pull the two parts of the case apart. Looks like the tricky part to be careful of, is to make sure the selector knob is in the Off position when opening case up. Also make sure that you carefully remove all parts and pieces. Sometimes the housing can bind and may make the dis-assembly a bit tricky. The image shows you the location of the screws as well as how it all fits together. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Liston Bailey 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 507
