跳转到主内容
加入维修社区 - 创建账户
HP Laptop 14-dk1022wm 是一款紧凑、经济实惠的设备,广泛应用于学生和普通职员的学业、工作及个人用途。
Its hinge is broken and cracking.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hello, I’m sorry to hear that your HP Laptop 14-dk1022wm has a broken and cracking hinge. This is a common problem that affects many laptops over time. There are a few possible causes and solutions for this issue:
  • The hinge may be loose or misaligned due to wear and tear or physical damage. You can try to tighten the hinge screws by following the instructions on this guide. Make sure you have the right tools and skills to do this, or seek professional help if you are not confident.
  • The hinge may be broken or cracked due to excessive force or impact. You can try to replace the hinge by following the instructions on this video. Make sure you have the right replacement part and tools to do this, or seek professional help if you are not confident.
  • The hinge cover may be broken or cracked due to cosmetic damage or aging. You can try to replace the hinge cover by following the instructions on this article. Make sure you have the right replacement part and tools to do this, or seek professional help if you are not confident.
You can find more information about your laptop’s parts and components on this page. You can also find more setup and user guides for your laptop on this page.
I hope this helps you with your HP Laptop 14-dk1022wm hinge issue. 😊
这个答案有帮助吗?
得分 0
2条评论:
@kingofspades you need to check your AI's links. "by following the instructions on this guide " There is no guide. It links to the HP Customer Support site.
完成的
@oldturkey03 I see! thank you for pointing out my mistakes!
完成的
添加一条评论
@donaldcrump besides all the technobabble from the AI in the preceding answer, all you have to do is to download the service manual for your computer from here The hinges are listed as part of the display assembly. Page 64 will tell you how to work on those as well as giving you the part number for the replacements etc. If the hinges are too broken, they may even have cracked the top case, so you may need to replace that as well. Sometimes it helps to post images of the damage. That way we can see what you see and hopefully guide you further.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Donald Crump 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 409
