跳转到主内容
Chinese Android phone mediated CPU and functions.
Why my phone is stack any his time
My is stacked in every his time
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
3条评论:
I don't know check yours setting
完成的
Hi @abrahamlencho, do you mean that your phone is stuck on one screen? If you're not able to turn it off manually, let it die and then turn it back on after it charges.
完成的
How can I download software to my phone
完成的
添加一条评论
1个答案
@abrahamlencho if it still does not work after you let the battery drain and then charge it to restart your phone, I would suggest you try the Recovery mode from here.
  1. Turn off the device
  2. Press and hold Volume Down key + Power key until the phone vibrates
  3. Let go of the buttoins when your phone vibrates. You should now see XOS Chameleon with No command
  4. Hold down power key about 2 – 3 seconds and press Volume Up key to enter Android Recovery
  5. Use Volume keys to select Menu
  6. Use Power key to Confirm
Be careful here that you do not clear your eMMC or set it to Factory mode. that will delete all of your data (pictures/contacts, etc) What you can do in that menu is to run either an Auto test or a Debug test and see what that tells you. After that reboot.
BTW you can also pop the back cover off and disconnect the battery. Then let it sit for a few minutes and reconnect the battery to see if that works.
Since iFixit does not yet have a guide for this, use something like this video to get the back cover off. While you work on your drive, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abraham lencho 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 741
