My tv black screen
My smart tv black screen
@salvadore40547 regardless of the make and model, you will have to initially approach this the same way on every TV.
First you need to verify that you have no image on all inputs. Try all of those. If it remains dark, unplug everything that is plugged in the back of your TV. unplug the TV and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide 在已经存在的问题里加入图片 for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
To get specific answers to your TV, you want to go ahead and let us know what make and model this is.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 104
Please Provide more information On what kind of tv you have?
由 King0fSpades05 完成的
