I’m sorry to hear that your BOSE Wave AWR1-2W has a low volume problem. According to some online sources, this model does have a demonstration mode that can be turned on or off by pressing and holding the “Play Mode” button for five seconds. When the demonstration mode is on, the display will show “DEMO ON” and the volume will be fixed at a certain level. When the demonstration mode is off, the display will show “DEMO OFF” and the volume will be . You can try this method to see if it solves your problem.
If the demonstration mode is not the cause of your problem, there might be other issues with your device, such as a faulty transistor, a corrupted firmware, or a damaged speaker. You can try to reset your device by unplugging it from the outlet and letting it rest for 10 seconds before plugging it back in. You can also check the speaker connections and make sure they are not loose or broken
If none of these solutions work, you might need to contact BOSE customer service or visit a nearby authorized service center for help
I hope this helps you fix your BOSE Wave AWR1-2W low volume problem. If you have any other questions, please feel free to ask me. 😊
@alex015 do you have this option on your Bose:
On the remote control, press and hold the Alarm Setup button until -SETUP MENU- appears on your Wave system display
Press and hold the Preset 1 button until -DEMO SETUP- appears
由 oldturkey03 完成的
Hi @oldturkey03 ,
Thanks very much for this. I saw the set up menu instructions for other models but it doesn't seem to be an option on this model.
Still trying to toy with other buttons to see if I can get any kind of menu to appear.
由 Alex015 完成的
@alex015 if it is not a menu issue etc. then the issue could most certainly be on the circuit board. I believe that your board has the Volume control IC U403 that is responsible for the volume. take a look around that and see if there are things that look well, odd :-) iFixit does allow you to ad images to your Question. Those are always helpful when looking at circuit boards etc. 在已经存在的问题里加入图片
由 oldturkey03 完成的
