跳转到主内容
苹果 2021 年的顶级智能手机。iPhone 13 Pro Max于9 月24日发布,配备6.7英寸ProMotion OLED显示屏、新的三颗后置摄像头系统和 5G连接。iPhone 12 Pro Max的继任者。
76 个问题 查看全部
iPhone boot loops while charging and randomly start functioning
Phone had its cases of bumps and falls, Has damage to certain areas of the phone (primarily the back glass near the upper edge) recently feel into some water with internals been exposed. Narrowed it down to damage contact pads of a curtain sensor or a faulty battery I'm not sure...phone is sensitive to being low on charger or sudden cold temperatures. Works fine when cancelling out the boot loop by letting it die and boot up on it's own . Help on dealing with this issue
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Let's start out by seeing if the phone will tell us what's wrong with it. Go to the Kernel Panics wiki page and follow the instructions to check for panic logs. If there are any, download the latest one and add the first page or so of it to your question.
iPhone Kernel Panics - iFixit
Adding images to an existing question - iFixit Repair Guide
Either a screenshot or copy n paste will work fine. If there are more than one panic logs check to see whether they're showing the same error or not; if they're the same ignore the older ones but if they're different we might want to see them as well.
Once we have the logs or have confirmation that there aren't any we can figure out what to do next.
这个答案有帮助吗?
得分 1
添加一条评论
Solutions to Resolve the Issue iPhone 13 Pro Max Keeps Restarting:
  1. Inspect for Physical Damage:
    • Solution: Carefully examine the device for physical damage. If found, consider professional repair services.
  2. Address Water Damage:
    • Solution: If the phone was exposed to water, power it off, dry it thoroughly, and consider professional water damage repair.
  3. Battery Replacement:
    • Solution: If you suspect a faulty battery, consult a professional for inspection and potential battery replacement.
  4. Avoid Extreme Temperatures:
    • Solution: Keep your iPhone away from very hot or cold environments to prevent temperature-related issues.
  5. Restore Software:
    • Solution: Attempt to restore the iPhone's software using iTunes or Finder in recovery mode. Follow Apple's official guidelines for the process.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Uraveragetechuser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 12
总计 54
