Change the radiator water
كيف يمكنني تصفية ماء الرديتر واعادة التعبئة
@nawaf55330 from the service manual:
DRAIN ENGINE COOLANT
CAUTION: To avoid the danger of being burned, do not remove the radiator cap while the engine and radiator are still hot, as fluid and steam can be blown out under pressure.
2. FILL ENGINE COOLANT
NOTICE:
Do not use an alcohol type coolant or plain water alone.
The coolant should be mixed with plain water (preferably demineralized water or distilled water)
Capacity of the coolant for Manual Transmission is 4.4 US qts. (4.2L) and 4.3 US quarts (4L) for the Automatic Transmission vehicles
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 32
总计 253
