跳转到主内容
任天堂于2019年9月20日发布了在Switch系列中更加实惠、且更纯粹的掌上游戏机——Nintendo Switch Lite,它有着一体式的手柄设计以及更小的屏幕。
Digitizer replacement but middle portion is unresponsive
I replaced the broken digitizer on my switch lite which was yellow with a grey one since I reshelled it as well and the new grey one works only around the perimeter but not in the middle for some reason I've read that the V1 V2 switches have different versions of digitizers and that causes this issue if you install the incorrect version but nothing on the lite version is it the same thing where each color is it's own version of the digitizer and it can't be changed to another color?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@diana_knows no it's not. The color differences do not relate in anyway to the digitizer. You may have gotten a bad digitizer. I would replace it once more. See if the seller can exchange that digitizer for a working one for you. Otherwise the issue could be the connector or the cable. Check for any tears as well as bend or corroded pins
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Diana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 97
