跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Torn wireless charging cover
9/23/23
I also tore the cover installing a new battery in my IP8.
Everything works including wireless charging but the new battery seems to drain really fast.
Could the tear be causing this or did I just get a bad battery.
Thanks
Chuck
1 minute ago by Charles Meyer
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@charlesmey43117 as long as nothing is internally damaged and you just tore the outer layer, use some electric tape or equivalent to keep it covered to prevent any damage. That should not deplete your battery. Try a new battery and re-evaluate. If you ruled out the battery, then you can always consider replacing the coil.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Charles Meyer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 11
