跳转到主内容
加入维修社区 - 创建账户
Repair guides and support for televisions manufactured by Sony.
Lower Half screen flickering
Lower Half of the screen is flickering on my KD 43X8000D Sony bravia
Mise à jour (09/22/23)
It is,like vibrating. No colour change. Only lower half us flickering. After switching on the TV. It starts flickering after 10 minutes. It is not damaged anywhere. It started few days ago.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Can you elaborate? Is it flickering on and off? How often does it flicker? What colors does it flicker between? When did it start flickering? Has it been damaged?
完成的
So the lower half is flickering on and off?
完成的
Yes. Only the lower half is flickering
完成的
添加一条评论
1个答案
@kumaresan29464 sounds like your TV is developing and issue with the panel. You do want to go ahead and open it up. You'll find that the main board connects to the T-con board, where two ribbon cables connect to boards which connect to the panel. Check that T-con board first. It is most likely under a sheet metal cover which you will have to remove first. Then check the ribbon cables for any tears, corrosion etc. Make sure they are fully seated. Check the board for any odd, damaged looking components. The ribbon cables control left and right side but not anything on the horizontal pane. That is done by the LCD driver boards which are the long skinny boards that the ribbon cables from the T-con board connect to. Something like like this Check those boards for any damaged component etc. Caution, those boards are not removable. So be careful when you check on those. Do not break the ribbon cables which go from the boards to the LCD panel.
It always helps to post some good images with your question. that way we can see what you see and hopefully guide you further.
It will also help if you post a short video showing what your screen looks like when it does the flickering. You can add a video the same way as you would images.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kumaresan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 305
