Won't grind beans
Will not grind beans, just hums
Does "hum" mean, that the motor turns, or is it stuck? If it turns freely, the culprit might be a broken belt; if it's stuck there might be a little stone or something wrong between the grindstones. In any case - I fear - you have to find a way to open it and get to the grinder.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 33
总计 295
3条评论
?? Cuisinart DCC-3200 is a coffeemaker not a bean grinder. I don't understand.
由 bill 完成的
dude, it's both. You can see the bean receptacle in the device image. Most coffeemakers also have bean grinders.
由 shingle 完成的
@jackiemjacobs I wonder if this is either a bad grinder or just clogged. The person that knows most about these coffee makers would be @vauweh Let's see if he can help you with this.
由 oldturkey03 完成的
