跳转到主内容
The XV20 series of the Toyota Camry is Toyota's 6th generation of the Camry sedan.
66 个问题 查看全部
Car is wobbling when driving
My 2000 toyota camry is wobbling when driving. It's really scary because there was noises coming from the front passenger tire area and now this wobbling like the car is off balance, plus my steering wheel is shaking and pulls to the left. What could it be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
@linda75783 there are a few possibilities. First check the tires and the rims. Take it to get those balanced if they are still decent. If not, replace your tires. Next would be suspension issues. Bad tie rods, balljoints and bad wheel bearings are all a possibility. Take a look under there and see if you can make out any obvious damage. I’d start with the wheels (tire/rim)
这个答案有帮助吗?
得分 1
添加一条评论
You might have a brake problem. A bad rotor, caliper or pad.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Linda 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 18
总计 104
