跳转到主内容
The Samsung Galaxy A72 is a midrange USB-C smartphone released in March 2021. It offers a 90Hz Super AMOLED screen, a Snapdragon 720G chipset, and 6-8 GB RAM.
10 个问题 查看全部
No network signal after restart
Hi
My galaxy a72 doesn't have any signal.I had a problem with unresponsive screen lately and I opened the phone to clean and check after getting advice from here.Today while at was ar uni the same problem occurred I restarted the phone just to get by until coming home to change the flex cable(I ordered aa spare one) and since then I have no network connection. Wifi works fine.I tried everything. Can the flex cable cause this problem?
Thanks in advance.
PS I checked my sim on my brother's phone and vise versa. My on my phone I stilldidn't have any signal.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@juangeas I can't seem to find where you asked about this before and what advice you got for that. Let us know which flex cable you are referring to. Also, let us know if our phone recognizes that there is a SIM card.
Time to open it up and check your coax cables. Make sure they are properly seated etc. Depending on what Flex this is, if you have a replacement, now is a good time to install it.If you need to to a deep dive, use Samsung's flowchart for that.
Use your PDF readers search function to locate the components in this document SM A725 Component Layout
Use any of these guides Samsung Galaxy A72 to get into your phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
juangeas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 44
总计 246
