跳转到主内容
Repair and disassembly information for Samsung's Galaxy A13 Android smartphone, released in March of 2022.
110 个问题 查看全部
Does a dead motherboard impact charging and battery health?
Newby repairer question here:
My friend recently gave me his Galaxy A13 that according to him just stopped working one day. With about 50% battery the screen simply went black and it hasn't powered on since.
I connected a charger and could see that it was drawing and holding charge, I suspect this is probably due to a dead motherboard. But it got my wondering, whilst I'm aware they're totally separate components, would a dead motherboard have any impact on a phone drawing or holding charge?
UPDATE @oldturkey03 These are the best I could do. Everything looks fine to my untrained eye. Hoping you can shed some light on the situation. Also apologies for the delay have been on holiday
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
@jsf11 yes to the drawing of any amps no to holding a charge. You motherboard gets the battery state of charge through the “gas gauge” and the power management then determines the charge/don't charge. I would start with a new battery and measure the voltage on the battery connector with the charger connected. You should get something around 4-4.2V
There is a possibility that this is caused by an issue with the charging board as well as the flex that connects it to the mainboard. Check those carefully.
Remember that your battery may charge and even hold a charge but may break down under a load.
Update (09/18/23)
@jsf11 just in case you need some extra guidance and if you do not have this already A13 Troubleshooting
这个答案有帮助吗?
得分 1
9条评论:
Thanks for your informative post @oldturkey03 much appreciated info!
UPDATE: So after a LONG charge I'm now getting feedback when inserting and removing the charger. The screen remains black but the vibration leads me to think this may be an issue to do with the LCD or the LCD Flex. Will do some further investigation.
完成的
@jsf11 that is good news. If you do have it open or if you have to replace the LCD, replace the battery as well. That way you only have to open it once.
完成的
Thanks for all your help and advice, the troubleshooting guide is very useful!
完成的
All seemed to be going well, I managed to replace the screen and battery without issue. Except the phone won't power on...
The screen flashes for a split second then goes off. If you hold the power button it just does this on a loop. I'm at a bit of a loss.
完成的
@jsf11 did you by any chance also replace the charging board? did you measure the voltage as I indicated on my answer?
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Joe Fisher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 34
总计 274
