跳转到主内容
加入维修社区 - 创建账户
True wireless earbuds case battery
Hey repair friends,
I have some LYPERTEC Z3 Earbuds (Not the ones in the header! But I had to choose something!) . I love them, but the Battery in the charging case does hardly hold a charge anymore.
I opened the case, no problem. Found the specs of the Battery (Type: ETL 902535 , 3.7V 800mAh 2.96WH)
Does anyone know where and how to find a Battery to replace the original? That would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @jens65174,
Usually the number string on a LiPo battery denotes the dimensions of the battery.
Regarding the battery dimensions shown on a LiPo battery, the convention used in battery manufacture, is that the first two digits is the height (depth, thickness) of the battery, in mm (millimetres) with a decimal point between the two digits, but it is not shown, the next two digits is the width in mm and the last two digits (or sometimes three) is the length in mm, e.g. 902535 = 9.0mm height x 25mm width x 35mm length
If it is the same size as your battery, then here's a supplier. There may be others I didn't search too hard. ;-) Search online for 902535 3.7V 800mAH LiPo battery to find other suppliers that may suit you better.
Note: The ETL marking is a battery certification mark for the battery.
这个答案有帮助吗?
得分 1
1条评论:
Thak you for your prompt answer! Tis actually helped a lot! Thank you
完成的
添加一条评论
添加你的答案
Jens 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 33
总计 1,030
