跳转到主内容
Repair guides and support for LED, LCD, HD and other Vizio TVs.
932 个问题 查看全部
Fuzzy Bottom Half of Screen
Hey all, I have a Vizio E43-E2 that suddenly became fuzzy on the bottom half of the screen. It was working fine until the most recent time I turned it on, and there were no power surges or outtages. The bottom half is fuzzy across all apps / inputs - I've included a couple of shots of the vizio home screen (hopefully you can see what I mean). I've tried manually rebooting, doing a hard reboot, and resetting to factory settings without success.
Any suggestions would be much appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@notdeadyet91042 Remove the back from your TV. Reseat all the flat ribbon cables connecting to all the boards. Check those cables for tears, corrosion,etc. Post some good pictures of your boards, cables etc so we can see what you see.
Since this is only on part of the screen the most likely issue here, is that the LCD gate drivers are starting to fail. That could come from the LCD driver boards (the long skinny boards that connect to your LCD via some thin ribbon cables). Those boards are not replaceable since they are adhered to the LCD via a special process. Of course, you could also check the Gamma IC on your T-con board (unlikely). Replacement boards are relatively inexpensive for your TV.
Ultimately, this looks like a panel error. There is no fix for it unless you can find the issues on your driver boards.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
1条评论:
@oldturkey03 thanks! I'll give that a shot and post some photos this weekend
完成的
添加一条评论
添加你的答案
not dead yet! 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 119
