跳转到主内容
Tecno Spark 6 Air mobile was launched on 30th July 2020. The phone comes with a 7.00-inch touchscreen display offering a resolution of 720x1640 pixels and an aspect ratio of 20.5:9. Tecno Spark 6 Air is powered by a quad-core MediaTek Helio A22 (MT6761) processor. It comes with 2GB of RAM. The Tecno Spark 6 Air runs Android 10 and is powered by a 6000mAh battery.
My phone display change how
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
5条评论
Hello! Could you give us a bit more info on your problem? Is your phone charged? What do you mean by "display change"? If you have any other info, we may be able to help.
完成的
How do change display tecno spark 6 air
完成的
@jaaquqqlqfdlonj
See the Most Helpful Answer below ↓
完成的
My chane display
完成的
Santosh, if you need to replace the display on a Tecno Spark 6 Air phone, see the previous answers already provided.
If you have a different issue, you'll need to explain more; we can't read your mind.
完成的
添加一条评论
2个答案
最有帮助的答案
@tecanospark7t since iFixit does not yet have a guide for that, use something like this video instead.
Replacement screens are readily available at many online stores. Pick a vendor of your liking , just make sure that you get the correct one for your version.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
这个答案有帮助吗?
得分 1
添加一条评论
@amaanabbasi, Unfortunately the link provided by my esteemed colleague @oldturkey03 has apparently been taken down so I can't just point you to his previous answer. However, I did locate another YouTube video showing how to replace the screen for your phone, assuming we're still talking about the Tecno Spark 6 Air, of course.
Tecno Spark 6Air Display replacement// Tecno Spark 6Air LCD replacement. Tecno spark 6Air teardown. - YouTube
The screen itself is readily available on many sites such as Amazon, eBay or AliExpress among others. Here's just the first one that came up on my cursory search.
Amazon.com: LAILINSHENG TFT LCD Screen for Tecno Spark 6 Air KE6, KE6j with Digitizer Full Assembly : Cell Phones & Accessories
Watch the video to get an idea of what tools would be needed; from my viewing I'd throw out this list.
  • Small Phillips screwdriver
  • Opening tool
  • 90% or higher concentration isopropyl (rubbing) alcohol
  • Glue
Hopefully that will tell you all you need to know.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tecano spark 7t 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 702
