跳转到主内容
The Infinix Hot 10i is an entry level smartphone with a 6.52 screen and a 6000 mAh battery released May, 2021.
Fingerprint sensor not showing on my phone
I can't find fingerprint sensor on my phone
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 35
3条评论
Finger lock show
My phone finger lock not show
What is the problem
完成的
@kokokhan have you tried the solutions in the original answer? What did you try?
完成的
Infinix hot 10i ka fingerprint is not working
完成的
添加一条评论
3个答案
已选择的解决方案
@emperorvibez first try to reboot your Infinix to check if your fingerprint sensor is working. IF that does not work you want to check your and update your software. Go to Settings==>About Phone==>System Update and let your phone check for any updates. If there are any, those should show up as Download Update. Use those to download and update your Infinix.
You can still clear your cache and other thing if the above did not work. Check sites like this one for how to clear your caches etc.
If none of that worked, you may have an actual hardware issue, like a failed fingerprint sensor. Since iFixit does not yet have a guide for that, try something like this video It is not the identical model but it will work for yours as well.
A replacement sensor is readily available at many online stores. Purchase one from a vendor to your liking, just make sure you purchase a fingerprint sensor for your exact model.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 7
7条评论:
why my Fingerprint is not working on my phone
完成的
@mikepaul27121 could be a failed sensor or issues with the software. Did you check the things I’ve mentioned in my answer
完成的
My fingerprint is not working on my phone
完成的
Fingarprint not showing problam please solve me.problam
完成的
@yusufbhati have you tried what was suggest in the original answer?
完成的
显示更多的2条评论
添加一条评论
  1. Navigate to Settings.
  2. Look up "System" using the search box and click on it.
  3. Choose Reset options.
  4. Reset Bluetooth, Wi-Fi, and mobile devices > Reset settings.
这个答案有帮助吗?
得分 2
2条评论:
Setelah di apdet finger frin
Tak ber fungsi
完成的
I have infinix note 10 pro mobile and its fingerprint is not working
完成的
添加一条评论
Not working sensor infinix hot 30i phone
这个答案有帮助吗?
得分 2
1条评论:
Why fingerprint not function
完成的
添加一条评论
添加你的答案
Emperor Vibez 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 69
过去 30 天: 294
总计 13,983
