cold battery will not charge where do you buy battery?
will not charge says cold battery
Update (09/25/23)
where do you buy battery for plus one watch
@frankdidente could be a bad battery. The battery has a temperature sensor, and a failed battery control board can give you that error. Start by replacing the battery.
Check this OnePlus Watch Teardown and see if this is something you would tackle.
这个答案有帮助吗?
I replaced the battery and it worked using battery from:
I just found this on AliExpress:
C$37.99 | new original for OnePlus XE202 Watch battery
https://a.aliexpress.com/_mOAz1z9
The wearable now works!
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 9
总计 245
3条评论
Could be a bad temperature sensor.
Li-ion batteries shouldn't be charged below 40 F ( ~ 5 C) so there is a sensor to check for this.
If you warm it up, can you make the message go away?
由 Allen 完成的
Not work my wacth
由 SIRAJ AHMED LASKAR 完成的
A comedian. Very funny. My wacth (sic)
由 Allen 完成的
