Fingering is disappeared in my settings
Fingerprint sensor is disappeared in my settings
@raorajput update your software first. If it still does not show after you upgrade your software, it is possible that your fingerprint sensor has failed and thus your software can't find it. Check on here for the setup and on here for possible fixes. Different model, same idea. If none of this works, you may need to replace the sensor. Problem is that guides for this are not easily found
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 34
总计 1,046
6条评论
Fix a network problem
由 Aziz 完成的
Infinix not 12 in no fingerprint work
由 Anup Kumar 完成的
Touch screen problam
由 So cut 24 So cut 24 完成的
由 Bikesh Majhi 完成的
Not work fingerprint
由 Broken Boy 完成的
显示更多的1条评论
