跳转到主内容
The Sansa Clip+ is a music player by SanDisk that was released in 2009.
Which component blew up and needs to be replaced?
After replacing the battery in my Sansa Clip+ everything seemed normal – turned on, navigation worked, radio playback was working – but when I tried to charge it I smelled a magic smoke. Once opened, I noticed a component that blew up. Don't know if I messed up with soldering job and shorted GND lead from battery to the test pad nearby, or I accidentally shorted Audio Jack pad to smth nearby – will redo both after replacing the faulted component.
Interesting to know why it blew up. Was it just my bad solder job? Or was it caused by a cable / charger supplying more current than the player circuit can handle? Or is it (a wild idea) prone to aging and it was first-time charging in the last 5 years?
Now I obviously need to know to replace it with... something. According to the Rockbox wiki photo this component has a marking "S21" with a white stripe on one of its leads. Is it a diode of some sort? Which replacements I can order in EU?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@krin_san if it is a diode it'll be a BAP50-03 general purpose PIN diode. Farnell, Digikey and Mouser seem to carry those. I do know that all of them have an sales outlet in the EU
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 213
