跳转到主内容
加入维修社区 - 创建账户
这是一款 Dell Latitude 设备,通过型号 7420 进行标识。它配有碳纤维外壳、触摸屏,以及用于解锁的指纹识别器。
Where is the CMOS Battery?
Where is the CMOS Battery located on the Dell Latitude 7420?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
Cmos battery is inbuilt with battery.
由完成的
Where do battery smos
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi @splitintwain
There is no separate cmos battery connected to the motherboard in a Dell 7420.
The RTC (Real Time Clock aka cmos) battery supply is provided by the main battery.
Here is the service manual for the laptop.
Go to p.27 (or p.30 depending on battery type installed), to view the procedure to remove the main battery.
Take note that it mentions that by disconnecting the battery that the laptop is RTC reset i.e. the BIOS settings will be reset to the default factory settings.
If you wish to reset the BIOS and restore any possibly corrupted settings by removing the battery you simply have to disconnect the battery cable from the motherboard and not remove the battery itself.
It may also be prudent that once the battery cable has been disconnected to press and hold the laptop's power button for 15 seconds, to ensure that all the residual power stored on the motherboard has been drained as well, before reconnecting the battery cable to the motherboard.
这个答案有帮助吗?
得分 2
1条评论:
Thank you, @jayeff, that is very helpful! And it also explains why I could not find the battery after a complete disassembly of the laptop. I appreciate the quick response!
由完成的
添加一条评论
添加你的答案
splitintwain 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 33
过去 30 天: 181
总计 9,000
