跳转到主内容
加入维修社区 - 创建账户
型号 A1502 / 2.6 GHz(睿频最高可达 3.1 GHz)或 2.8 GHz(睿频最高可达 3.3 GHz)双核 Intel Core i7 处理器,配备 4MB 共享三级缓存。
Start up issues- flickering screen.
My computer just started flickering between the passcode screen and the start up screen when i open it from sleeping (closed). I can force it to shut down by holding the power button and then restart it, it boots up fine.
I haven’t been able to find this particular issue in searches and am hoping someone here might know what is happening and what i need to do to repair.
I am now only able to use it when connected to the power-cord- i gave s new battery coming to replace the current one. (Not sure if this could be related to the flickering)
Thanks in advance for all help.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
I'm not sure if the poor condition battery is related to the flickering issue. If it only occurs after waking from sleep if might have to do with your sleep/wake settings. It would be a good idea to try restoring the default settings. You could also try an SMC reset or NVRAM reset. As a last resort you could try reinstalling the OS. Good luck!
这个答案有帮助吗?
得分 2
添加一条评论
Given the systems age it’s likely the battery is just too old. Install this gem of an App to check your batteries health CoconutBattery
这个答案有帮助吗?
得分 1
3条评论:
I actually already installed that after looking through other forum questions. This battery is showing 0 health.
完成的
@daphnevega - Bingo! You need a new battery.
The flickering is do to the backlight doesn't have power stabilization logic so as the MagSafe contacts break contact due to dirt the system will flicker when dependent on AC power. Also note some actions will require more power than the MagSafe charger can offer so even with a clean MagSafe the power demand of the CPU can disrupt the backlight power needs.
完成的
Thanks, Dan- I am glad to get some consensus that it is the battery- that I am already prepared to replace. I love this laptop and am hoping for a few more good years out of it. :)
完成的
添加一条评论
添加你的答案
Daphne Vega 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 46
总计 815
