跳转到主内容
加入维修社区 - 创建账户
Vivo V5 是由 Vivo 推出的一款智能手机。该手机于 2016 年发布。
Display Screen is Broken.
The screen is broken and the batter is also finishing up too fast . What could be the solution for this ? .
回答此问题 我也有这个问题
这是一个好问题吗?
得分 13
14条评论
Vivo 1609 Phone display broken solution
由完成的
Display of Vivo v5 is damaged
由完成的
See my previous answer for how to replace the screen yourself.
由完成的
Battery not working properly
由完成的
My display is broken what can I do
由完成的
显示更多的9条评论
添加一条评论
1个答案
最有帮助的答案
Yash wanth, you will need to replace the screen, and as long as you're at it, a new battery replaced at the same time will give your phone a new life. I didn't find any iFixit-style step by step instruction guides for your phone, but there are a couple of videos made by the same author that show separately how to replace the battery and the screen.
I would suggest following the battery replacement guide first until the battery is free, then pick up on the screen replacement video and follow through removing the screen. Once the screen is back on, go up to the point where you would reconnect the battery then switch back to the battery video to finish up.
Vivo V5 Battery Replacement
Vivo V5 /5s LCD-Touch Replacement
Although the video shows the technician using a hot air gun to heat the screen adhesive for removal, in actuality a normal hair dryer will work fine; just let it heat longer obviously since it doesn't get as hot.
Other than that, search places like Amazon, eBay and AliExpress for the parts you'll need to do the job; I saw screens available on Amazon and eBay for under $25 USD so they're readily available and the phone is old enough that the parts are inexpensive now.
Good luck; let us know how it goes! Take lots of pictures as you do your repair and use those to author your own iFixit guide to screen and battery replacement! It's fun, easy and the community will appreciate you!
这个答案有帮助吗?
得分 2
1条评论:
What’s a price of battery and display.
由完成的
添加一条评论
添加你的答案
Yash wanth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 16
过去 30 天: 69
总计 3,336
