跳转到主内容
加入维修社区 - 创建账户
Fingerprint issues after screen change
After screen change my fingerprint sensor not showing in settings, changed sensor and it's now showing in settings but when trying to setup fingerprint at start it immediately timed out ? See video clip
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
With the 6 series, google did program the fingerprint sensor to each specific device but luckily they did make the calibration software available to the public. Just be aware it is finicky at times and may take a few tries to get it to work.
https://pixelrepair.withgoogle.com/udfps
这个答案有帮助吗?
得分 0
5条评论:
Tried it a number of times and it seems to calibrate it always said successfully updated but no message it worked on the phone but didn't work still the same problem 🙁
完成的
@georgehyslop did you purchase a used/refurb display or genuine google display? I've heard that in order to calibrate the sensor it may need a brand new un-programmed sensor.
完成的
Thank Jesse I have ordered a new sensor so I will update when it arrives hopefully it will sort it out 🙄 if not anyone looking for a 6pro 😁
完成的
Just fitted a new sensor today and did all the recalibration tool bit etc but has soon has you put your finger near it its still timing out. Has Google or anybody have any other ideas 🤪
完成的
same problem as George Hyslop, someone has any alternative solution? Tried absolutely everything, using the udfps calibration tool, with USB debugging enabled, trying entering secure mode, etc etc etc. multiple times, I don't know what else is left
完成的
添加一条评论
添加你的答案
George Hyslop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 453
