跳转到主内容
The Husqvarna YTH20K46 is a 24-horsepower lawn tractor or riding lawnmower with a cutting width of 46 inches.
11 个问题 查看全部
Mower won’t start, no click or spark. Maybe a safety/kill switch?
So, I started the mower up just fine and drove about 5 feet and it shutoff. I tried to start it again, and nothing. No noise or crank at all. So I bypassed the ignition with a flathead and it sounds good but just won’t get any spark. I took the fuel line off and fuel is coming out when attempting to start. However, the spark plugs have absolutely no spark at all. So I replaced them and nothing change.
To sum it up, turning the key does nothing. But I can bypass it with a flathead and it just cranks but gets no spark. Fuel system seems good, so I’m curious if there’s a safety/kill switch somewhere.
It has a new tank of gas, new spark plugs, fuel is spitting out, oil is new, filter isn’t clogged.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@jaredjones1556 here is the schematic for the mower you listed
First thing to check would be the seat kill switch and after that the wiring to the junction box and the ignition switch. To start, the ignition switch connects B + S + A1 so your clutch safety switch is right in the midst of it as well. Oh yes, check all of your fuses too.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jared Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 78
过去 30 天: 309
总计 2,569
