跳转到主内容
加入维修社区 - 创建账户
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
I didn't want to solder the blue
Hello I have similar problem, just for the yellow line anywhere on the board would be fine?
@oldturkey03 Really sorry for bothering you but I can afford a ps4 and I'm trying to do it my self
I didn't want to solder the blue directely to the capacitor so I prefered to the line
Tried scratching it
Do you know if these are connected or whole different lines?
Thanks again for the help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@mzhbxhwfgvmubmf anywhere within that area on the board will work
Update (08/26/23)
@mzhbxhwfgvmubmf yes, you could have just connected it to the Via. (That is the name for the hole in the board :-)
Try to use smaller tools for this. Get a cheap scalpel from the local animal supply store or similar and scrape carefully. I'd try some solder mask around the Via and solder the wire on after. You know it would have been easier to solder to the capacitor ;-)
这个答案有帮助吗?
得分 1
4条评论:
Perfect thanks a lot one last request plz for the blue line (connecting to the capacitor) I will put a little wire but is their a temperature limit for not burning the capacitor?
( I only have these 2 pads removed)
完成的
@mzhbxhwfgvmubmf I usually use wires from either an old small transformer that I took of a TV board or from an old display cable. There is not enough amperage to have to about it being melted.
完成的
So the 2 scraches ( pinned by arrows) are from 2 differents rails? If yes I'm gonna give a shot with the capicitor :)
完成的
@mzhbxhwfgvmubmf yes, you need to keep those separated.
完成的
添加一条评论
添加你的答案
E A 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 101
