跳转到主内容
发布于2018年9月21日,型号为A1921,A2101,A2102,A2104。支持GSM,CDMA / eSIM或 nano-SIM / 拥有64,256或512GB容量可选 / 有银色、金色、深空灰可选。(读作iPhone 10XS Max)
381 个问题 查看全部
Auto Restarting every 3 minutes
Hello Guys, The device was physically damaged and had a original display replacement. But the device has still the same 3 minute reboot. Tried all the software troubleshooting and also tried removing all the flex except battery and display to find the sensor but couldn't resolve the issue.
This is the panic log.  Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
最有帮助的答案
@oldturkey03 is exactly right, the PRS0 sensor is a pressure sensor that works with the barometric vent and is located on the charging port assembly flex cable. So yeah, in addition to the new screen you're going to need that lightning port assembly replaced as well.
If you're interested in learning more about those kernel panics that are rebooting the phone, Alisha ( @flannelist ) has written an excellent wiki article on the subject; it point you directly to the charging port after finding that missing sensor: PRS0 line.
iPhone Kernel Panics - iFixit
Sorry to say, iFixit hasn't gotten around to creating a lightning port replacement guide for your phone yet, but I did find a good one on a Spanish side called Nadie Me Llama Gallina, or Nobody Calls Me Chicken. Use it with the Chrome web browser's automatic translation and you won't have any trouble; just note that "battery" gets translated as "drums" and "flex cable" come across as "tablecloth"; other than that it's straight forward and easy to follow.
Manuales / Apple iPhone Xs Max / Flex with load connector and lower microphone - Nadie Me Llama Gallina
The parts themselves you can get anywhere; I usually start with Amazon, eBay and AliExpress depending on how cheap I am vs. how fast I want it. Of course, you can support iFixit's repair efforts by purchasing the part right here; don't forget to pick up a sheet or two of the precut adhesive for sealing the screen back up when you're done.
iPhone XS Max Lightning Connector Assembly
iPhone XS Max Lightning Connector Assembly图片
产品
$24.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
24.A Monish.M 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 25
总计 130
